Cloning Drives w/ Macrium Reflect Help
Speedmc33
42
I am trying to copy my 128 gig ssd contents over to a 250gb ssd. Whenever I clone it, it leaves an unused partition that I want to change. Instead of keeping the space on the NTFS SSD auto at 128 I want to increase it to the max.
Clarification: I want to switch from a 128 OS Drve to a 250gb OS drive If I could have some tips on that, that would be great 🙂
Pics:
http://i.imgur.com/FGvyowI.png (Shows the leftover space)
http://i.imgur.com/9VCkN12.png (I can't increase the partition size more)
Thanks in advance!
not dragging them over right.
Drag the first partition down then then second. For the second one click on Cloned Partition properties. Then set it so that the free space is 450MB after. Then drag the last partition to the left over 450MB
