Hi
My PC specs:
I7 10700k
Rtx 3080 fe
16gb ram
Msi z490 gaming carbon WiFi motherboard
I built the PC half a year ago and was using it by connecting my monitor, which surprisingly only has dp port and no hdmi even the box it came in with and sold on ebay with was Asus rog swift pg278q.
I been playing games and everything was good. I started mining and was told to connect monitor to PC to get some extra performance for mining.
I connect monitor to display port on motherboard back io port and other end to monitor.
No signal
Change setting in bios to enable igpu and multi monitor mode. Installed driver for Intel graphics card igpu Intel uhd 630. Restart and still no signal from display port from motherboard.
I removed graphics card completely, reset cmos and tried and still no signal.
Tried removing power source of pc from mains and remove power off and remove power source from monitor to mains waited 20 mins connected everything, turned monitor on and then turned pc on and no signal.
I have no idea what to try next.
Please help.
Thanks
My PC specs:
I7 10700k
Rtx 3080 fe
16gb ram
No signal
Please help.
Thanks
