IIRC, the H100i V2 uses a Fan/Pump header for power and not SATA?
In that case, it would need to be installed (or at least connected) to the motherboard.... at that point, it may aswell be mounted on the CPU (as you'll need something installed anyway).
Why would you want to test before install, out of curiosity?
