Closed loop water cooling options.
laterterror
26
Hi. I'm looking to upgrade my CPU and am possibly looking to do some overclocking. I don't know much about closed loop water cooling systems and am not sure what would be the best option. I have an AM3+ motherboard and a 120mm fan slot at the rear of my case where it would be housed. Any suggestions?
No need, a high end air cooler is almost on par with the closed liquid coolers and cost less. Look at the silver arrow and Noctua for examples. If you want to step up in terms of cooling then a custom loop is the step up, something I dont advocate.
I disagree, aio go on sale all the time. Frys antec 650 for $33. I have corsair h90 and my temps never go above 57c, before they were 80 plus. I have I7 950 which is probably one of the hottest chips thermally
