Clrmamepro Help
G
Guest
Guest
Archived from groups: alt.games.mame (More info?)
I usually have the extra's zipped into one file. Ex. cabinets.zip,
icons.zip etc...and clrmamepro works great. Now I have all the files
unzipped into their respective directories. Is there a way to tell
Clrmamepro to search the "unzipped" files to check if I have all the proper
files with the updated DAT files?
Thanks
P.
> Thanks
> P.
What made you want to unzip them? I found that just dropping the most
recent *.zip into the rebuilder updates all the extras without any extra
maintenance. Zipping also has the benefit of smaller HD space being
used etc...
MCR
MAME(tm) - History In The Making
www.pleasure-dome.org.uk
* MCR Wrote in alt.games.mame:
>> cabinets.zip, icons.zip etc...and clrmamepro works great. Now I
>> have all the files unzipped into their respective directories.
>> Is there a way to tell Clrmamepro to search the "unzipped" files
>> to check if I have all the proper files with the updated DAT
>> files?
> most recent *.zip into the rebuilder updates all the extras
> without any extra maintenance. Zipping also has the benefit of
> smaller HD space being used etc...
With the extras, HD space savings is negligible as a zip, but I agree
that unzipping is just messier and unnecessary.
David
clrmamepro supports unzipped files by default. You only have to be aware
of the standard storing scheme:
<rompath>\<setname>.zip for zipped sets
<rompath>\<setname>\<rom 1 .... rom n> for unzipped sets.
So for example the setname of the controlpanels is (defined in the
datfile) "cpanel". So you either you store cpanel.zip in a rompath or
your create a subfolder called "cpanel" in a rompath and store the
unzipped png files in there. Note: The rompath is the parentfolder of
cpanel.
Sounds complicated? nah....just follow the upper 2 rules and look at the
datfile to get the setname
Roman
The reason is that "full torrents extra's" come none zipped.
P.
"MCR" <mark.coleman10@ntlworld.com> wrote in message
news:EUzWe.566$QU3.375@newsfe1-win.ntli.net...
>> proper files with the updated DAT files?
>> Thanks
>> P.
> maintenance. Zipping also has the benefit of smaller HD space being used
> etc...
> MCR
Got it...thanks
P.
"Roman Scherzer" <cmpro@1und1.de> wrote in message
news:dger6c$qve$1@online.de...
> datfile) "cpanel". So you either you store cpanel.zip in a rompath or your
> create a subfolder called "cpanel" in a rompath and store the unzipped png
> files in there. Note: The rompath is the parentfolder of cpanel.
> Roman
no reason....rebuilder zips them optinally when you add new stuff to
your collection....rule #1: don't manually add files, always use the
rebuilder (prefered method) or scanner's fix missing 😉
