CM 690 II Advanced compatible with these parts?
nils925
13
Hi, I've been looking for new parts, and I wonder if a can get this PSU in a Cooler Master CM 690 II Advanced case. The PSU is a Cooler Master Silent Pro M2 1500 W (I know it has an overkill wattage but I can get it really cheap, at the price of a 750 W PSU). Also, would a Noctua NH-D14 fit in that same case? Thank you.
So, do you mean that I need to remove the fan that is placed like next to the motherboard, and then I can install it elsewhere? And about that PSU... Are you sure it isn't too long? Because it is longer than most.
The fan placement I am referring to is on the side cover itself. The cover has places for 2x 140mm fans. The case does not come with factory fans installed in these positions and you would have to buy ones and install them if you wanted some there. The rear fan is fine and will not be in the way and should remain where it is placed.
I am positive the extra long ATX PSU's fit.
