Cm elite 361 how to connect front usb and caae fan issues
peep1988
217
Hi forum people I just recently did my first pc build ://pcpartpicker.com/b/ for about 500 after Mir I like this case but how in the hell do the front panel usbs connect to I'm a noob sorry for being a noob lol also the side panel wil fit a 120mm fan but it won't fit with my xfx 1gb 7850 boo had to get a yate loon 120x20 mm fan let's hope it fits. One last thing it takes 280mm fans in the back is there anyway to mod it to fit a 120mm. Any help is appreciated
With regards to the front pannel USB's, there will be USB headers on your motherboard, if you cant see them look in your motherboard manual. There will be a cable running from the usb slots at the front of the case that will need connecting to any of the USB headers.
With regard to the rear fans, the 261 has space for 2 x 80mm fans, and that's the biggest that will fit. Any bigger and they would interfere with the I/O ports on the motherboard.
Found the cable plugged into jusb 1 and nothing tried jusb 2 and 3 nothing is it possible its broken although it seemed fine to me
