CM HAF 932 Top Fan Advice aka confusion
abhi_jollyguy
138
I have a confusion or may be I don't know that how to equip 120mm fan on the top of CM 932 along with 230mm fan ????
Do anyone knows this so plz help me and also tell me how to euip 120mm fan along with 230mm one on the top.
I know that lots of ppl have put 3x120mm fans in place of 230 mm one on the top but I want to put 1x120mm fan along with the 230mm one on the top
because in coolermaster official site it is stated as that we can put 120mm along with 230mm fan on the top.
Thank you all in advance
I have a Coolermaster HAF 932. The extra 120mm fan can be mounted in the very front of the top panel. The bezel that sticks up at the front needs to be removed. Remove the square rubber pad to get to the mounting screws. Check the diagram in the case instructions.
Why do you want to install a fan at the top front of the case? Ventilation, airflow, and cooling with stock fans are excellent.
