Hello There,
Can anyone suggest me where can i find only fan for CM Hyper 212x, My old fan is not working now
Fan Dimensions (LxWxH) | 120(L) x 120(W) x 25(H) mm |
Fan Speed | 600-1,700 RPM ± 10% |
Fan Airflow | 24.9 - 82.9 CFM ± 10% |
Fan Air Pressure | 0.3-2.03 mmH2O ± 10% |
Fan Life Expectancy | 40,000 hrs |
Fan Noise Level (dB-A) | 9-27.2 dBA |
Bearing Type | Rifle Bearing |
Fan Connector | 4-Pin (PWM) |
Fan Rated Voltage | 12 VDC |
Thank you so much sir, I will contact them right away.Contact Cooler Master, tell them that you have a Hyper 212x and that the fan quit, ask them what part you need to buy. Depending on how old your cooler is they may just send you a replacement. Its just a high pressure standard size 120mm cooler master CPU fan with a rifle bearing.
Fan Dimensions (LxWxH) 120(L) x 120(W) x 25(H) mm Fan Speed 600-1,700 RPM ± 10% Fan Airflow 24.9 - 82.9 CFM ± 10% Fan Air Pressure 0.3-2.03 mmH2O ± 10% Fan Life Expectancy 40,000 hrs Fan Noise Level (dB-A) 9-27.2 dBA Bearing Type Rifle Bearing Fan Connector 4-Pin (PWM) Fan Rated Voltage 12 VDC
I have found this fan, Will that work with CM Hyper 212x , just in case.Contact Cooler Master, tell them that you have a Hyper 212x and that the fan quit, ask them what part you need to buy. Depending on how old your cooler is they may just send you a replacement. Its just a high pressure standard size 120mm cooler master CPU fan with a rifle bearing.
