[SOLVED] CM k350 case and Deepcool Neptwin V2
JohnnyAx222
17
Hey, so im looking for new cpu cooler for my i7 4790 but i have this case with little room and this is the best cooler i can get atm. So my question is will it fit? I have side panel removed and plan to use it like that, i just wanna know will the heatsink touch the case on the top.
The cooler is 159mm tall.
The case support maximum height of 148,5mm.
If you can live with a open side panel then buy it,but cant you find anything else?
Does it have to be Neptwin V2?
