cm tx3 evo cpu fan replacement to Noctua 92 x 92 x 25 NF-A9 PWM
Ossiose
5
So my cm tx3 evo fan is too loud for my taste and i want to replace it with either Noctua 92 x 92 x 25 NF-A9 PWM or redux 1600 version, do you think these fans would be too poor for cooling and temperatures would rise much, and if u got some better ideas as 92mm coolers, lemme know
The airflow will affect the cooling the most, the first one flows as much as the fans on Hyper 212. If the RPM on it is higher it will be louder though.
Noctua 92 x 92 x 25 NF-A9 PWM : Airflow: 78,9 m³/h, Static Pressure: 2.28 mmH2O
Noctua 92 x 92 x 25mm NF-B9 redux-1600 PWM : Air flow: 64,30 m³/h, Static Pressure: 1,61 mm H2O
Coolermaster hyper tx3 evo : Air flow: 43.1 m³/h, Static Pressure: 2.63mm H2O
i see tx3 default fan has static pressure compared to these, and i wonder how much it means for cooling i mean noctuas have much better airflow and A9 doesnt have that much difference between static pressure but redux version is 1mm H2O lower, how much that would affect to temperatures
okay it actually might be 2-3 celcius higher temperatures than default, but its quieter and i dont know if its fan or because i removed whole cooler and added new thermalpaste, maybe that fked up. just telling if anyone else is considering to buy this fan for replacement.
