cmd console ..crazy issue.. emergency...
Keerthi Sagar
7
I've been running windows 8.1 and.. well as everybody knows .. There are tonnes of problems with the activation... so......... I tried using a third party software and according to the instructions, a cmd console is to pop up but nothing happens.. i tried another third party software but same issue... the cmd window opens for a nano second and closes..... thus no activation... any support is appreciated... Thanks in advance..
build 9600
windows 8.1 pro
No, there aren't
There is no legitimate "third party software" for Windows activation that I know of. Link to this, please?
Generally, you type in the license key, Windows talks to Microsoft, it activates.
At most, you have to do it via the phone robot. 5 minutes, done.
What exact issues are you having?
first of all.... thank you for taking time off to help me out.. really appreciate it.. :)
no there aren't
error 0xc004c003 error 0x8007232B error 0x8007232B etc......
There isn't....
however.. that's not my problem......
like i said.. my issue is... " on running the activator, a cmd console window is supposed to open up.. However this isn't happening... i checked in the app tray/task manager.... no cmd running in the background...
once it completes (which only takes a couple of minutes ) the comp is supposed to restart ... but.. this is isn't happening...I've left it on for about half an hour... but to no avail..."
Not trying to call you a pirate, but given a valid, legal install, there is no need to use an 'activator'. It just activates. At most, you have to do it via the phone robot. There is no valid "third party software" for this.
An ISO from MS.....bought or just downloaded?
With your license key in hand, call MS and get it activated.
Yes, I've had to do the phone thing a couple of times.
The way to fix? Don't use that activator thing. Bite the bullet and activate via phone.
Your current solution is not working. Continuing to try that is simply a waste of time.
