CMD.pf file problem
CroCoo96
Commendable
Nov 28, 2016
Hey, i have a problem with cmd.exe
I deleted cmd.pf file from Prefetch Folder. When i opened cmd.exe the cmd.pf file doesn't appear in Prefetch again. What is the problem?
Just checked: I had two "cmd.exe-abcdef.pf" in that folder, deleted them, then starter cmd.exe - it opened correctly, but no .pf file anymore. Still, my cmd.exe works as expected.
Again - you (or your "gaming community") have no business messing up with Prefetch (or any other Windows) folders and files.
In a gaming community..the staff check me if cmd run corectly. They say the cmd.pf need to appear imedialty in prefetch when is open, but at me doesn't appear. I know that means nothing to you, but I want to know just what is the problem and how to fix it.
