[SOLVED] Cmos battery
Jenka
9
Hello.
i have problem with motherbord Toshiba satellite C855-S5350.
Few Day ago i poll out CMOS Battery and press power and screen show me reset bios, i not do any changes and remove the power.
return the battery and my screen not up and not work from VGA Port.
Without battery the screen not up.
i tested the battery and show me 1.44 Volt .
the problem can be low voltage on battery or Have problem With Bios?
thanks For Help.
D
if it can't boot it can't do anything, get a new batter at a local battery store. bring the old one in and they will show you what to buy. if you put that new one in and it doesn't work, well you have motherboard issues.
put in batter, boot, choose default settings and save and exit, done.
D
Deleted member 14196
Guest
