Hey Everyone,
So I was an idiot and was messing with the bios when I shouldn't have been and ended up messing up my computer surprise surprise (SPECS at the bottom). Long story short the Monitor, Keyboard, and Mouse do not work when the computer starts. The case fans and LED's fire up no problem however there are zero beeps on startup.
I tried taking out the CMOS battery several different times, even leaving it out up to three hours, and even tried clearing by short-circuiting the 2-pin CLRTC for 5-10 seconds as suggested by the owners manual. The one important thing to note here is that when the computer was unplugged I didn't know I could use my finger to release the CMOS battery. Instead I used a screw driver. I'm curious if its possible if residual power could have been stored and this fried the mobo?
I've taken out all the PCI cards and even the ram one at a time switching from DIMM slots. I've even gone so far as to move the jumper from the CPU_OV enabled to the default of disabled with no luck.
With the fact that there a no beeps at start up means its either the PSU, CPU, or mobo correct? I'll buy another CMOS battery hoping that will fix the problem but if not what would you recommend? I know its troubleshooting at this point but curious if anyone has any insight?
Mobo: Asus Prime Z370-a
CPU: Intel i7-8700k Coffee Lake
CPU Heatsink: Noctua NH-D15
PSU: Seasonic FOCUS Plus Series SSR-650FX 650W
GPU: Gigabyte GeForce GTX 1060 6gb
RAM: Ballistix Sport LT 8GBx2 DDR4 2666
SSD: Samsung 850 EVO 2.5"
OS: Windows 10 Pro 64-bit
Any help would be much appreciated.
Thanks,
Merlin
Thanks,
Merlin
