CMOS Clock problem on Dell OptiPlex GAx
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
I have an old Dell PC OptiPlex GAx. Recently I decided to upgrade the RH 8
installation to Fedora core 2. Since I had to reset the BIOS I thought that
the easiest way would be to remove the battery. So I did but now the clock
goes like mad. The minutes go like seconds, hours go like minutes and so
on. Also CMOS does not seem to remember that I had two drives in the PC
though it does remember clock. Has any body seem problem like that ? IS
there a cure for it ?
Tom
if you would like to reply directly please remove [no #spam] from the email
address below
Mr.Ter[no #spam]ntlworld.com
How about replacing the battery? ... Ben Myers
>Tom
>address below
Battery backwards?
"Mr Ter" <one6699@hotmail.com> wrote in message
news:2pk6muFlh273U1@uni-berlin.de...
> that
> Tom
> email
> address below
youve got the polarity crossed try reversing the connection on the SB
> that
> Tom
> email
> address below
Ben Myers wrote:
Well, I've tried everything new battery, reversing polarity still clock goes
like mad.
Tom
>>that the easiest way would be to remove the battery. So I did but now the
>>clock goes like mad. The minutes go like seconds, hours go like minutes
>>and so on. Also CMOS does not seem to remember that I had two drives in
>>the PC though it does remember clock. Has any body seem problem like that
>>? IS there a cure for it ?
>>Tom
>>email address below
address below
Ouch! Reversing polarity of the battery is not good for the health of a
computer. At this point, I have to speculate that reversing the polarity caused
irreversible damage to the motherboard's built-in clock. I suspect that the
only way to fix the problem is to replace the motherboard... Ben Myers
On Thu, 02 Sep 2004 10:50:02 +0100, Mr Ter <one6699@hotmail.com> wrote:
>like mad.
>Tom
>>>Tom
>>>email address below
>address below
Ben Myers wrote:
Thanks Ben but the clock was racing before I tried to revers polarity.
Tom
> caused
> the only way to fix the problem is to replace the motherboard... Ben Myers
>>goes like mad.
>>Tom
>>>>8 installation to Fedora core 2. Since I had to reset the BIOS I thought
>>>>the clock goes like mad. The minutes go like seconds, hours go like
>>>>minutes and so on. Also CMOS does not seem to remember that I had two
>>>>drives in the PC though it does remember clock. Has any body seem
>>>>problem like that ? IS there a cure for it ?
>>>>Tom
>>>>email address below
>>email address below
address below
Fine. The motherboard is still malfunctioning, and you had stated earlier that
you might have put in the battery upside down previously. I still suspect that
the only way to fix the problem is to replace the motherboard. Don't shoot the
bearer of bad news... Ben Myers
On Thu, 02 Sep 2004 18:40:15 +0100, Mr Ter <one6699@hotmail.com> wrote:
>Tom
>> caused
>>>goes like mad.
>>>Tom
>>>>>Tom
>>>>>email address below
>>>email address below
>address below
Ben Myers wrote:
Thanks Ben, I'm not trying to shoot the messenger. I suspected so much
myself. I hoped may be there was a dip switch or something on the mob that
would reset it. I only paid £25 for it and it served for more than two
years so I can't complain here. I saw someone selling the GXa mob on the
ebay for £4 so I may go for it.
Thanks- Tom
> that
> suspect that
> shoot the bearer of bad news... Ben Myers
>>Tom
>>> polarity caused
>>> Myers
>>>>goes like mad.
>>>>Tom
>>>>>>RH 8 installation to Fedora core 2. Since I had to reset the BIOS I
>>>>>>thought that the easiest way would be to remove the battery. So I did
>>>>>>but now the clock goes like mad. The minutes go like seconds, hours go
>>>>>>like minutes and so on. Also CMOS does not seem to remember that I had
>>>>>>two drives in the PC though it does remember clock. Has any body seem
>>>>>>Tom
>>>>>>email address below
>>>>email address below
>>email address below
address below
How sure are you of the condition of the "new" battery? I had the
same experience of a fast clock on a GX1 mobo; I tried two "new"
batteries I had had but not used without joy, but a third bought
freshly cured the problem. Finally, as the bettery voltage is so low,
I'd be surprised if reversing the polarity on the CMOS would cause
permanent damage.
"Fixer" <steve@kelly90.wanadoo.co.uk> wrote in message news:<ch2sm9$1r3$1@news5.svr.pol.co.uk>...
> > that
> > Tom
> > email
> > address below
Peter Felgate wrote:
Well the batter was straight from the shop.
Tom
> permanent damage.
>> > thought that
>> > Tom
>> > email
>> > address below
address below
Thata doesn't mean it was good! Who knows how long it had been on the
shelf.
Tom
news:2puhbhFopgjtU1@uni-berlin.de...
> Tom
>> permanent damage.
>>> > thought that
>>> > minutes
>>> > in
>>> > Tom
>>> > email
>>> > address below
> email
> address below
Tom Scales wrote:
As far as I can tell there was nothing wrong with the old one. The PC
remembered it's time and config very well.
Tom
> shelf.
> Tom
>> Tom
>>> permanent damage.
>>>> > thought that
>>>> > minutes
>>>> > in
>>>> > Tom
>>>> > email
>>>> > address below
>> email
>> address below
address below
Huh? I thought you wrote:
The minutes go like seconds, hours go like minutes and so on.
I assumed you meant in the bios; and that's usually caused by a duff battery....
Mr Ter <one6699@hotmail.com> wrote in message news:<2puks1Fpi2frU1@uni-berlin.de>...
> Tom
> > shelf.
> > Tom
> >> Tom
> >>> permanent damage.
> >>>> > thought that
> >>>> > minutes
> >>>> > in
> >>>> > Tom
> >>>> > email
> >>>> > address below
> >> email
> >> address below
