CMOS low battery after replacement
snowdog64
5
My computer gave me a low cmos battery message and when it booted in to the operating system it had the wrong time and date. So I turned it off, unplugged it and replaced the cmos battery. When I booted it up it still said low cmos battery and i changed the time in bios and when i booted into the operating system it still had the wrong date and time. Any Suggestions???
I too am having the same problem with my intel 845, everytime I switch on the UPS, the system starts automatically and I get a message "CMOS/GPNV checksum bad, date time not set". Please help.
couple of things:
(1) Don't buy cmos batterries from Biglots, dollar stores ect. and check the dtd on package. There is a self life for these batteries and occassionally they set on a store self for long periods of time.
(2) If battery is KNOWN to be good, then most common cause is a MB/bios chip problem that is causing excessive current drain on the CMOS battery - These batteries are for very low current drain applications. Would require a DVM to verify. (a) measure voltage before putting in and (b) measure voltage with it in place (which may be difficault to do).
As Motopsychojdn indicated, a mem check would be a good idea.
