CMOS reset help GA-78lmt-USB3
Goyim
96
I'll make the story short. I tried overclocking my CPU and failed. There is a constant beep and default settings on bios didnt change anything. so now I have no choice but to reset it manually. Only problem is, where do I find the button/jumper or even battery to reset it? I cant find it anywhere.
The battery is under the PCI-E 1x slot. If you have a two slot video card you probably have to remove it to find the battery.
It's labelled CLR_CMOS. This jumper has always worked just fine on my Gigabyte m/b. It's certainly worth trying first as it saves a lot of messing about removing the battery,
Your m/b manual should give you this information and will have a diagram showing the locations of the various jumpers.
Edit: Note that you should remove the power cord before resetting the CMOS.
An easier option would be to just unplug either the power or reset wires from the motherboard and use that on the clear cmos pins and then press which ever botton you used, saves the hassle of trying to get a screwdriver in there. And yes make sure the power to the pc is disconnected first.
Why unplug the pc? I always cleared cmos with the pc still plugged in, I just turn off the pc first. (I also made a handy tool by taping a screw to the end of a pen, with the screw head facing outwards to reach in and short the clear cmos pins.)
