Transferred from the memory thread we hijacked:
wusy wrote:
Note the different RPM/noise fan being used on the coolers. 45dB vs. 35dB is a noticible difference
But 45dB of noise at 50cm (2 inches) is not going to be 45 dB when the case is closed and tucked under my desk 4 feet away from me. With that in mind, I dont expect Ill hear that thing over my case fans at all.
wusy wrote:
No 92mm can ever match a 120mm HSF under the same condition (CFM, noise, room temp...etc.)
But it just did. Yes a bit louder at 100% but cools just as well.
the 92mm CNPS9500 had the exact same temp as the Shogun and Katana. Was only one degree behind the Ninja and the Mine.
I doesnt matter what CPU they are on. Its a relative comparison to each other. So if you put them all on a much higher wattage CPU, the temps go up relatively the same for all. That one degree difference isnt going to turn in to a 15 degree difference is it? Maybe it is, Im not an expert in thermaldynamics.
I get what you are saying. Im just saying that the superior design of the 9500 allows it to work as well as larger 120mm HS's. As I said before, if they made a 120mm version of the 9500 how do you think it would do against the rest? I think it would crush the competition because of its design.
See Im switching from agp ddr400 to pci-e and DDR2 so its a new mobo, ram, cpu, and HS all in one shot. Thats a big chunk of money all at once. I wont skimp on a mobo cause I want to use it for a while. So I have no choice to go REALLY cheap on CPU, and ram. when I recoup some money I will definately take your guys advice and buy a better CPU. Then Better ram. I also dont want to hang a 1kilo piece of metal on my motherboard and have it take up the whole case. Thats why I chose the 9500. Once I get a newer 65nm cpu I wont be needing as much cooling and the Zalman will work all the way up to a core duo.
