I have Time Warner cable and everything goes through coaxial cable with them. I have very few ethernet ports in the walls in my home, though I have coaxial cables ports in almost each room that they can make active. I want to move my wireless router to another room, though I will need to purchase a Coax-Ethernet adapter such as this one: http://www.amazon.com/NETGEAR-MCAB1001-Coax-Ethernet-Adapter-Black/dp/B001N85NMI/ref=sr_1_1?ie=UTF8&qid=1401986768&sr=8-1&keywords=MCA1001v2
1.) Aside from the cost, are there any disadvantages to doing this? Will using an adapter like this slow my network down?
2.) Are there any other adapters like this that you can recommend?
Thanks!
Thanks!
