So I am in a bit of a situation, basically there is no ethernet ports in my room (yep i know). I have a coaxial cable coming out of the wall that I don't use ( See question 1) and my motherboard doesn't have a built-in network card (https://www.asrock.com/mb/Intel/Fatal1ty%20Z270%20Gaming%20K4/index.asp here is the motherboard) so the only way I can have internet is via ethernet or if i buy a third-party network card. I use a power line adapter as a solution but these are very unreliable, my IP keeps bam-boozling it self and it keeps changing to 169. something but simply reseting the router does the trick. the problem is that the router and the modem is in my mum's room, i don't live above her room , i live above the living room where the router used to be and it got moved to her room (i don't even know why). Anyway enough rambling.
Q1: Can i have a proper, reliable and efficient connection through coaxial cable if i use a coaxial to ethernet cable (I am not sure if this is even a thing, someone told me but i am not 100% sure, if someone could point me in the right direction then i would appreciate it) and would i get the promised speed that my ISP says i would. When i test the wifi (5GHz) from my phone, i get 150~Mbps download and 30Mbps upload, sometimes i get the odd 220~ but it doesn't matter, i sohuld be getting 250Mbps but i learned to live with it anyway. Just getting above 60 download would be nice. So the TL;DR question is : Can i have 200+ download if i were to use something that provides internet through coaxial to ethernet and into my PC.
Q2: If i were to use a NIC, which one should I use for my speeds ? My ISP informed me that i should be getting 250 Download and 30 Upload on the 5Ghz frequency (I never get 250 but it comes to 220-230 which is close enough for me). Should I even use a NIC? I game a lot and downloading games is a tedious process and with the additional 100/150 download that process could be made a little easier to deal with.
Thank you in advance.
