Question COD Advanced Warfare V-Sync problem
gesseler555
16
Hey, I got a Asus VZ27AQ 1440p monitor with a 75hz refresh rate. Typically, in all games I've played if I set the Vsync option to ON, it should cap the framerate to the monitor's refresh rate. That's how it's worked in all other games I've played on this system.
However there's a problem with AW. I set the refresh rate to 75hz (74.95 something) and turned Vsync ON, but now the framerate is capped at 60 fps, as though if my refresh rate was in the 59.95 setting (which it's not). How should I get it to lock fps at 75 instead of 60?
I have a 1080Ti and with Vsync OFF I can get well over 120 fps at all times with all options set to maximum so I know that's not the problem. Any ideas?
