its has a factory clock of 650/1000 and i oc it to 695/1170 and the max fps which is 91 is still there.
i have cat 9.8
hd 4850 ice q4 TRUBO 512mb
6 gb ddr2 667 mhz
e4500 2.2 ghz
Again though, if you're refresh rate on you're moniter is 60, you can only see 60 frames to begin with. As far as I'm concerned, its just wasted performance.
Now, if you have a 120Hz CRT, then you really get the extra benifits...
haha..... who would make a game default capped @ 91FPS? i spose u can't use the rest, and so it won't stress ur gpu as much..... maybe this is the problem with crysis? 😛
which means crytek would have lulz over many gamers
