Code Program PS3 remote to Philips Soundbar B5 Fidelio
pilotsh
173
Hello,
I wish to sync my new Philips B5 Fidelio sound bar to the AMP button of my PS3 (CECH-ZRC1U) remote. The PS3 manual says I need a THREE digit code to sync. Does anyone know what the universal remote sync code is for the Philips sound bar please?
Thanks for the links, both not quite the solution.
I went to both Sony and Philips and they just keep passing the buck to each other.
Sony gave a few numbers simialr to their amps, and Philips said "we don't have numbers". Both useless.
So far, still have many remotes. 🙁
I think the Philips sound bar uses infrared for its remote and the PS3 remote uses Bluetooth so there will be a compatibility problem.
I think you would need a converter to make this work
Sony did make an infrared box for its PS3 but I don't think its available any more
https://www.engadget.com/2008/11/25/infrared-to-bluetooth-converter-roundup-get-universal-control-o/
Logitech also did one for the harmony remote
https://www.amazon.com/Logitech-Harmony-PlayStation-Discontinued-Manufacturer/dp/B00267S7XW/ref=sr_1_1?ie=UTF8&qid=1406821096&sr=8-1&keywords=logitech+ps3+adaptor
NOT Solved yet. The PS3 remote DOES use infrared and Bluetooth, so it should be programmable. When I have the time I will go through all 999 codes 🙁
