So, I spilled a small drop of coffee through the top of my PC and it landed on to the top portion of my GPU..I quickly pulled the power from the wall and opened it up. It didn't look like it was touching any of the solder points on the back so I wiped it off and waited till it was dry before plugging it back in. Once I plugged it in, everything was fine for the first hour but then my second screen, which is plugged in through the display port, went black. I could still move my mouse over to that screen and drag my windows from it as if nothing changed, but still black.
I reset the PC, everything was normal again for about a half hour and the same thing happened, so I just unplugged my display port to finish an assignment.
Now I tried to plug it in again and reset, but the PC isn't detecting a second screen at all... could the coffee have somehow only managed to fry my DP and nothing else on the GPU or do you think something else is up?
