I have read over and over that coil whine coming from a CPU cooler is not possible, not really a thing. I have heard the same advice that "some fans just emit a sound at certain RPMs," etc, even here on Tom's. I had something extremely similar to coil whine coming out of a CPU cooler, and would just like people to be aware that this is possible. I have since replaced the cooler, the chirping is gone, and my sanity is restored. I am posting this only as evidence. For reference, this is an old ASRock 970 Extreme4 mobo with an AMD FX-8300 and a stock cooler.
The system was emitting a high-frequency scratching/chirping noise would perfectly accompany pretty much anything happening on the monitor; highlighting text, opening windows, closing windows, watching video, anything that changes pixel content (regardless of frame rate). Because of this, I assumed that it was my video card and that I was stuck with it, having read so many times that there's nothing you can really do about it in a GPU.
When I finally got sticking my head in the system and poking around, I was extremely surprised to be able to mute the chirping by gently touching the CPU cooler. Unplugging the cooler (only for a few seconds, of course) also made it go away. I made a short video to demonstrate, putting up a youtube video on the screen so that pixels would be changing and it would chirp unassisted. (Note that I had to touch up the audio channel a lot - cranked up level, added some compression, eq'ed out bottom end. Please forgive the background noise coming from my family).
Fans obviously have coils, but I'm not sure how or why this would happen. Is it possible that the video card's variation in drain on system power could cause the circuit powering the fan (already PWM, by the way) to modulate to the point of being audible? Is this technically coil whine, or something else?
