https://www.evga.com/support/faq/FAQdetails.aspx?faqid=59535
Coil whine is in no way harmful for your card, and does not affect performance or longevity.
Coil whine is simply the vibration of the coil in an inductor as the power passes through it. On a high end graphics card, ten or more large inductors would help provide power to critical components on the card.
This vibration is similar to running a damp finger around the rim of a wine glass. Every inductor in every electronic device has some coil whine, but the vast majority of inductors whine well outside the hearing range of humans. On occasion, an inductor coil vibrates at a frequency in the range our ear can detect. This is particularly common if your card is processing 3D...
