[SOLVED] Coil Whine on multiple B550 AORUS Elite Motherboards - Help
Rogurzz
410
I have tried multiple B550 AORUS Elite motherboards and I still get coil whine on them despite changing it.
My specs are:
  • Ryzen 5 3600
  • GIGABYTE B550 AORUS ELITE
  • ASUS STRIX GTX 1070 8GB
  • Corsair RMx 650W PSU
I have tested the system with a different PSU which is an EVGA SuperNOVA GS 550W Gold and the problem still persists.
I am out of ideas. Should I worry about it?
I noticed my GPU whines under load, but its not the same noise at idle.
Do you think my GPU could be messing with the power delivery on my motherboard?
I would not rule that out electronics can do funny things. I would get a empty cardboard roll from like paper towels put one end up to your ear and stick the other end inside the PC move it around till you find exactly where it's coming from.
