Many Thanks for your explanations.
Yeah It only happens when I'm using the battery. The only thing that happens when I'm not using the UPS battery, is that when I'm downloading something at high speeds, if I'm using the audio jack in the back of the PC, I can hear some noise in the headphones (but very very low), like the "coil whine" noise. I think it's normal too right, since onboard sound normally isn't the best option? (The audio jack and the LAN port are very close, so maybe the audio jack is picking some sort of interference?). Anyway, I don't use the onboard sound anymore, since my headphones are using a little USB "soundcard".
Also, I can hear some coil noise coming from the graphics card when playing games, but nothing too high if the case is closed I can't hear it.
And yeah, the microphone interference (using the back mic jack) and the coil whine coming from the PSU and UPS only happens when the UPS is using the battery (for example, during a blackout).
So, all of this is completely normal, right?
Many thanks for your explanations
