Hi!
I built a system with following components in June and was using it for deep learning without any problems. However, I started experiencing coil whine while training a deep learning model couple weeks ago. I'm using Ubuntu for deep learning but I get a similar noise when I'm playing games on Windows (not as much though). Initially I thought it was from the GPU and replaced my gpu but I am still experiencing the same issue. Right now, my best guess is the motherboard but I am hesitant to replace it. Since it is still under warranty, should I replace it? Did anyone experience this problem? Thanks!
GPU: ASUS GeForce RTX 2070 Turbo 8G EVO, 8192 MB GDDR6
Motherboard: ASUS Prime Z390-A Gaming Mainboard Sockel 1151
Memory: Corsair Vengeance LPX 32GB (2x16GB) DDR4
CPU: Intel Core i5-9400F 2,9 GHz
PSU: Seas Modular Prime Focus Modular (80 + Platinum) 850 Watts
