Cold Cathode vs LED
heavyartillary9
Respectable
Sep 29, 2016
1,184
hi! i was wondering what would be better for lighting up a pc, cold cathode or led, what are the benefits / downsides of each. i have no experience with either so any help is greatly appreciated 😀 !
Ive honestly never come across that.
The bottom will probably be brighter, and wash out the LEDs at the top.
If you look at my system (using two cathodes) you can see just how bright this is (in full daylight)
https://drive.google.com/file/d/0B9sVYppAq0qXTVBxSGJvNHgyMVk/view?usp=sharing
If you see the front grill, those are LEDs, a deeper, richer blue than the washed out interior. (I like my cathodes because they are bright, but I normally recommend LED kits like the HUE+)
Cold cathodes are generally brighter, and more washed out than LEDs are.
If you want the components really lit up, they are a better* choice. They are also generally cheaper.
LEDs are more customization (depending on kits), more vibrant colors, and more true colors.
LEDs are mostly considered the better kits for lighting, their colors are more accurate and not as overwhelming.
how bad would a mix look ? like a 12inch cold cathode at the bottom of my case, and an led strip on the top or side, closer to the components ?
