Color laser printer A5 card stock feeding
Rosenda
Hello,
Has anyone had experience with HP CP1215 printer printing color A5 size card stock. It does not have a single feed tray. If you have used this model or a similar one, how best are heavier, smaller sized papers fed. Would you recommend other entry level color laser printers?
Thank you.
using card stock, most printer have a back cover that flips out, to accommodate heavy weight paper.
the use of card stock strains the tiny springs,
you get what you pay for.
if you decide to get another colour laser, check to see IF it will support card stock.
dont rely on sale staff, they are there to sell.
