Color Problem On My Monitor
mainanonlinetea2
16
I Have Problem With My Monitor
The Edge Of The Screen Is Appearing More Yellow Instead Of Pure White,I Just Using The Monitor For About 4-5 Month
Monitor That I Used is LG20MP38HQ
Can Someone Have Suggestion What Should I Do?
You can't do anything... I have ten like that in my company and after a year of using, every of thats monitors has a some anomally. I had try to use the warranty period for couple of thats monitors and return them to seller for fixing, but after some time problem will apear again.
After some time research i find that this type of monitor has a problem with adapters. After years of using he start to mix voltage and that is cause of all problems.
For you. Best solution is to use the warranty period and after they fix problem buy new adapter for that monitor.
