combine cpu and monitor
What is the particular CPU you are looking to use? Lenovo is not in the CPU manufacturing business, that's the realm of AMD and Intel. You'll still need some other components between the two. The brands don't matter, it's the socket the CPU goes into on the motherboard and the motherboard's compatibility with the CPU.
If you are asking if you can connect a Lenovo Laptop or Tower PC to an external HP monitor, then the answer is yes
