Hi there
Please excuse the possibly confusing following question but I'm trying to see if I can do what I think I need to...although if anyones got a better way I'm all ears.
Setup is currently simple.
2 x Imac (in same office, back to back)
1 x Macbook Pro
All running off wifi from 1 modem / router.
What I have now is a NAS which I want to connect directly to both Imacs as the wifi transfer rate is too slow for the large file sizes we shift about. (Photographer and Graphic Designer). Currently, to move files to the NAS we just plug in 1 Imac to the NAS using and Ethernet cable. Works a treat. Moving files between the Imacs is also quick and easy if I connect them directly using an ethernet cable.
What I would like to do is this.
Connect 2 Imacs and NAS to Ethernet switch so that they use the switch to transfer files between themselves and the NAS but still access Internet via WIFI.
I have an older, now unused, WIFI Modem Router (Netgear CVG824g) which I was wondering if it would make a suitable switch?
Will the NAS be able to pick up it's own IP from using the 824g as it's only point of access to the network?
Any thoughts?
Thanks. Curtis
1 x Macbook Pro
Any thoughts?
Thanks. Curtis
