Comcast increased DL speed to 105; can my MOTOROLA SB5101U utilize that?
redwing634
Guest
Apr 8, 2007
15
I currently have my home network on a MOTOROLA Surfboard SB5101U. Previously I had 50Mbps from Comcast but they just increased it to 105Mbps. The question is, will my modem make use of those extra speeds, or is it capped out at a certain point? Likewise for my Linksys wireless router (which I believe is the Linksys WRT54GL)?
You need to replace your SB5101U Cable Modem because it is DOCSIS 2.0 modem and only supports up to 38 Mbps, not 105 Mbps. $81 Motorola SB6141 modem seems a good one.
Your Linksys WRT54GL router may be another issue because it only has four 10/100 LAN ports that usually support 50 to 70 Mbps speed totally. If you have 4 computers connected to the router and access to Internet, then these four computers share 50 to 70 Mbps bandwidth. It might end up 12.5 to 17.5 Mbps bandwidth for a computer from time to time. Using a gigabit router like ASUS N66U, you can utilize all 105 Mbps bandwidth.
