G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
i tryed to open the command box by using the run box when it flashes up this
is what it says am i doing something wrong?
H:\windows\system32\command.com
h:\windows\system32\autoexec.nt. The system file is not suitable for running
ms-dos and mircrosoft windows applications.
choose close to terminate the application
even when i select ignore it closes the command window what am i doing wrong
mirkin
G
Guest
Guest
Hi
Please see if the following article helps:
"Error message when you install or start an MS-DOS or 16-bit Windows-based
program"
http://support.microsoft.com/?kbid=324767
Will Denny
MS MVP Windows Shell/User
Please reply to the News Groups
"mirkinman" <mirkinman@discussions.microsoft.com> wrote in message
news:BD02C97C-C10A-4081-806B-E0BC6C7E8516@microsoft.com...
>this
> running
> wrong
> mirkin
G
Guest
Guest
Q: Did you select Command prompt link from Start/All Programs menu? or did
you start CMD ? Or Command?
DO look at the contents of your Autoexec.NT & Config.NT files.
Do you have XP SP2 AND Avast antivirus on this system?
Study this advice from Torgier Bakken, MS-MVP:
Is there a reference to a autoexec.nt file in the error message?
The autoexec.nt problem is most likely caused by a worm or if you have
WinXP SP2 and AVAST (antivirus software) installed, it also can cause
this error.
You can put back the standard version of autoexec.nt/config.nt by
copying a backup copy held in %windir%\repair\ to %windir%\system32\
(%windir% is typically C:\Windows) instead of using the procedure in
the KB article above.
Could be caused a trojan or something similar, e.g.
TrojanDownloader.Win32.Dia.a, more about this here:
http://groups.google.com/group­s?selm=5f6f139.0409140618.7493­­24fe%40po...
Also, AVAST (antivirus software) can be the cause if you
have WinXP SP2 installed:
http://groups.google.com/group­s?threadm=8PCdnSzBqtmadsPcRVn-­­gQ%40comc...
Maurice N
MVP Windows - Shell / User
>this
> running
> wrong
> mirkin
