Command prompt and regedit do not work
dann
11
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hey there, if I run cmd or regedit from the run command a DOS box opens up
but does nothing, it just hangs. This affects other things like ping,
nslookup and other DOS interface commands. The only way I can get some kind
of command prompt is buy typing command.com and this doesn't support ping and
what not. And to access the registry I have to type regedt32. I've run full
Virus and Spyware scans but all seems ok.
Any help is appreciated.
Thanks in advance
Dann Rees
G
Guest
Guest
To repair all system files, go to Start/Run, and type (or paste in): SFC
/SCANNOW (see: Description of Windows XP and Windows Server 2003 System File
Checker (Sfc.exe):
http://support.microsoft.com/default.aspx?scid=kb;en-us;310747 )
Mark L. Ferguson
FAQ for Windows Antispy
http://www.geocities.com/marfer_mvp/FAQ_MSantispy.htm
"Dann" <Dann@discussions.microsoft.com> wrote in message
news:B88D15A3-F939-4287-A113-5C52541315C8@microsoft.com...
kind
and
full
> Thanks in advance
> Dann Rees
dann
11
Hey there, thanks for the prompt reply. However this did not fix my problem :(
If I run cmd.exe directly from c:\windows\system32 its fine. But if i type
cmd in the run command it runs c:\windows\system32\cmd.com and still hangs.
Cheers
Dann Rees
> Checker (Sfc.exe):
> Mark L. Ferguson
> kind
> and
> full
> > Thanks in advance
> > Dann Rees
