Command prompt randomly running
Zorcom
15
Hi community!
I'm currently running on windows 10 and for some reason command prompt (cmd) randomly opens, runs a command and then closes all in around a split second! I ran 2 full scans using different anti-virus softwares (malwarebytes and AVG) and both have said that my pc has no threats. I was wondering if there is anyway that i can force cmd to not close so i can see what is happening inside it? Help will be greatly appreciated.
Thank you
I dowloaded hitmanpro and it detected some threats others could not, hope this fixes it, thanks!
UPDATE: Im still getting it 🙁
Could be a service starting up for one of your programs. For example, my Vpn service loads a batch file to load the Vpn client, try to determine the location of where the command prompt starts from, and execute the code in it and see if it seems malicious.
Is it doing it when you open something specific, or when something is open? There are a couple programs I use that uses command prompt (mostly older programs that, while they've been updated over the years, still have the original code at the heart). Whenever you notice it, check what all you have open and see if there is any type of pattern
