Comment on my dual PC build.
Oct 25, 2018
8
Hello, I would like the forum to comment on my dual PC gaming/streaming rig on how I can improve it. I want to be able to stream 1080p or higher with 60fps. Games that I am planning to stream are games such as CSGO, Fortnite, Dead by Daylight, The Forest and League of Legends.
Gaming PC Specs:
- CPU: Ryzen 5 2400G
- CPU Cooler: DeepCool Captain 360Ex
- GPU: GTX 1070 8GB
- RAM: 16GB 3000MHz
Streaming PC Specs:
- CPU: Ryzen 5 1700
- CPU Cooler: Enermax ETS
- GPU: GTX 750 (I really don't know if GPU is really needed)
- RAM: 16GB 2400MHz
- Game Capture: Elgato HD60 Pro
Please comment on what should I change or what can I add in order to meet the requirements I want. Thank you for your help!
I want a dual PC Setup in order to avoid a lot of usage on the CPU and get better performance when streaming.
CPU: AMD - Ryzen 7 2700X 3.7GHz 8-Core Processor ($309.79 @ OutletPC)
Motherboard: ASRock - Fatal1ty X470 Gaming K4 ATX AM4 Motherboard ($141.98 @ Newegg)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory ($134.99 @ Amazon)
Storage: Crucial - MX500 500GB 2.5" Solid State Drive ($84.85 @ OutletPC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($45.89 @ OutletPC)
Video Card: EVGA - GeForce GTX 1070 8GB FTW Gaming ACX 3.0 Video Card ($369.99 @ Amazon)
Case: Fractal Design - Focus G (Black) ATX Mid Tower Case ($57.98 @ Newegg)
Power Supply: Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply ($63.48 @ OutletPC)
Total: $1208.95
Generated by PCPartPicker 2018-10-29 14:22 EDT-0400
This setup will do both to your satisfaction. I'm telling you a dual setup isn't going to be better.
Thank you for your addition! Seems tempting to do this instead. Thing is I wanted to go for a dual pc Setup in order to avoid a lot of usage on the CPU and have better performance overall.
For those games a single ryzen 7 2700x based system will be more than fine.
Yeah I figured my specs where an overkill to stream the games I want to stream. Thank you for the advice!
Thank you so much! Alright, I'll send you a private message when the build is all done. Thank you once again for your information!
You can perfectly fine get away with a cheaper b450 board as the x470 won't give you anything extra you'll use and then get a gtx 1070ti which will help you in games.
