Comp wont turn on after installing water cooling
fortuneflyer777
7
hi, i have a P5K SE Motherboard, with c2q q9550 cpu. after installing water cooling, pc wont turn on. Fans does spin for a half second, if i dont plug the 12v rail everything works fine. I've checked theres no leaks and defective hardwares, cpu pins in good condition.
please help
rubix_1011
Contributing Writer
CPU block isn't seated correctly and shutting down due to thermal? Are you sure your pump is powered and pushing coolant? If it isn't cooling your CPU, a waterblock isn't a very good passive cooler.
What WC setup did you install?
Conumdrum
2,397
Okay, lets get past the 10 questions. Please post the list of parts you bought, and post pics of the setup.
You probably mismounted something, have massive air in the loop, or some other issue. Since you bought the parts from a real store I guess they should be able to help you out hoprefully.
fortuneflyer777
7
OK, heres couple of pics of my setup...
The pump
Radiator
I bought:
A chinese made pump
Radiator
CPU waterblock
T shaped plastic thing?! attatched with the outflow tube (don't know what it is)
No water bottle, i used plastic tube instead
Conumdrum
2,397
I give up. Best of luck.
CPU waterblock. Made by Bob? Fred?
Pump. Nice if you gave a link so we could look at the specs.
Fans? Ambient temps?
You prolly installed it wrong.
fortuneflyer777
7
OK, so i've just tested the power with my multimeter, psu power runs fine but the mb atx12v power plug was fried :eek: , and some parts were running hot
videl
1,154
I would recommend buying a pump with external power, that way you don't have to use up power from the PSU. Unless you want to buy a new power supply with high wattage and amps, and that would cost a nice sum.
