D darylnj Reputable Mar 23, 2014 3 0 4,510 Mar 23, 2014 #1 i'm tired of buying batteries i've decide to just use the laptop on 110v, is there a way i can stop the orange battery light from constantly blinking.
das_stig Glorious Jul 24, 2009 8,530 176 46,190 Mar 23, 2014 #2 Nope, part of power circuitry, unless you cut the led legs to stop them getting signal. Upvote 0 Downvote
D darylnj Reputable Mar 23, 2014 3 0 4,510 Mar 23, 2014 #3 das_stig : Nope, part of power circuitry, unless you cut the led legs to stop them getting signal. thanks Upvote 0 Downvote
J jarotech Dignified Oct 13, 2012 3,927 2 16,960 Mar 25, 2014 #4 Hi, you can always remove the battery. Or put a black tape on the led. Upvote 0 Downvote
D darylnj Reputable Mar 23, 2014 3 0 4,510 Mar 25, 2014 #5 thanks but with the battery out the light still blinks guess tape is the answer Upvote 0 Downvote
