Compact pc downgrade. need help!!!!
HenryyRoberts
28
Hi again,
my situation is that i need to go to a LAN event in November and my mid-tower is going to be too big for me to transport it. I have a Zalman z9 plus. I'm looking for a compact case that's easier to transport but that will hold these:
AMD FX-8350 (with a single 120 coolermaster Seidon)
Nvidia GeForce GTX 670 Kfa2 edition
Corsair CX600M
Mushkin Redline 8gb 1866Mhz (2x4gb config)
WD Blue Caviar 7200rpm 1TB
and a disk generic disk drive
The reason why i haven't stated that i have an Asus m5a97 R2.0 is because i understand that i will have to buy smaller mobo to cater for the case, suggestions on which would be greatly appreciated
Thanks
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=9150564&CatId=8582
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1418809&CatId=7245
I got you a corsair cube case that is great and compact in getting the job done and a ASUS M5A78L-M LX PLus mobo that supports your hardware and supports your CPU. It's only CFX support [strike]so if you want a SLI board I can look for one.[/strike]
Unfortunately i cannot find a board that supports SLI that is FX and MicroAtx... sorry man.
don't worry about SLI bro my graphics card is way too over priced for me to buy a second when i could just sell it and get a 1/3 more performance for about £100 more, i'm still torn for a case though more suggestions for that would be cool if you can.
***Also i need help for where to buy the mobo as i live in teh UK not america 😉 😛
