Yudhbir Singh :
I couldn't find any as well, but I might be wrong. 204 pins might be the same as 240 pins, but I have no idea. If it isn't, I would resort to buying a new laptop, they'll work much better.
Hynex Laptop DDR2 Sdram 1 GB 667 MHZ | eBay
http://www.ebay.in/itm/Hynex-Laptop-DDR2-SDRAM-1-GB-667-MHZ-/221787256747?pt=LH_DefaultDomain_203&hash=item33a38cf7ab
what do you say about this one....
My detailed specs are as follows {Through CPU-Z}
Binaries
CPU-Z version 1.72.1.x32
Processors
Number of processors 1
Number of threads 2
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 3.580 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Pentium T2390
Codename Merom
Specification Intel(R) Pentium(R) Dual CPU T2390 @ 1.86GHz
Package (platform ID) Socket P (478) (0x7)
CPUID 6.F.D
Extended CPUID 6.F
Core Stepping M0
Technology 65 nm
Core Speed 797.9 MHz
Multiplier x Bus Speed 6.0 x 133.0 MHz
Rated Bus speed 531.9 MHz
Stock frequency 1866 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 1024 KBytes, 4-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 14.0x
Max VID 1.250 V
Temperature 0 57°C (134°F) [0x2B] (Core #0)
Chipset
Northbridge Intel GL960 rev. C0
Southbridge Intel 82801HBM (ICH8-ME) rev. B1
Memory Type DDR2
Memory Size 1024 MBytes
Channels Single
Memory Frequency 266.0 MHz (1:2)
CAS# latency (CL) 4.0
RAS# to CAS# delay (tRCD) 4
RAS# Precharge (tRP) 4
Cycle Time (tRAS) 12
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR2
Module format SO-DIMM
Manufacturer (ID) Qimonda (7F7F7F7F7F5100000000)
Size 1024 MBytes
Max bandwidth PC2-5300 (333 MHz)
Part number 64T128021EDL3SB2
Serial number 02108411
Manufacturing date Week 25/Year 08
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 3.0-3-3-9-12 @ 200 MHz
JEDEC #2 4.0-4-4-12-16 @ 266 MHz
JEDEC #3 5.0-5-5-15-20 @ 333 MHz
Monitoring
Mainboard Model 30D9 (0x000000E0 - 0x00002308)
LPCIO
Hardware Monitors
Hardware monitor ACPI
Temperature 0 63°C (145°F) [0xD22] (TZ01)
Hardware monitor Battery
Voltage 0 10.80 Volts [0x2A30] (Current Voltage)
Capacity 0 4752 mWh [0x1290] (Designed Capacity)
Capacity 1 4752 mWh [0x1290] (Full Charge Capacity)
Capacity 2 4752 mWh [0x1290] (Current Capacity)
Level 0 n.a. [0x64] (Wear Level)
Level 1 100 pc [0x64] (Charge Level)
PCI Devices
Description Host Bridge
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2A00
Revision ID 0x03
Description VGA Controller
Location bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2A02
Revision ID 0x03
Description Display Controller
Location bus 0 (0x00), device 2 (0x02), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x2A03
Revision ID 0x03
Description Multimedia device
Location bus 0 (0x00), device 27 (0x1B), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x284B
Revision ID 0x03
Description PCI to PCI Bridge
Location bus 0 (0x00), device 28 (0x1C), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x283F
Revision ID 0x03
Description USB Controller (UHCI)
Location bus 0 (0x00), device 29 (0x1D), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2830
Revision ID 0x03
Location bus 0 (0x00), device 29 (0x1D), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x2831
Revision ID 0x03
Location bus 0 (0x00), device 29 (0x1D), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x2832
Revision ID 0x03
Description USB 2.0 Controller (EHCI)
Location bus 0 (0x00), device 29 (0x1D), function 7 (0x07)
Common header
Vendor ID 0x8086
Model ID 0x2836
Revision ID 0x03
Location bus 0 (0x00), device 30 (0x1E), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2448
Revision ID 0xF3
Description PCI to ISA Bridge
Location bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2815
Revision ID 0x03
Description IDE Controller
Location bus 0 (0x00), device 31 (0x1F), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x2828
Revision ID 0x03
Description SMBus Controller
Location bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x283E
Revision ID 0x03
Description Ethernet Controller
Location bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x168C
Model ID 0x001C
Revision ID 0x01
Location bus 2 (0x02), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x10EC
Model ID 0x8139
Revision ID 0x10
DMI
DMI BIOS
vendor Hewlett-Packard
version F.33
date 04/29/2008
ROM size 1024 KB
DMI System Information
manufacturer Hewlett-Packard
product Compaq Presario C700 Notebook PC
version F.33
serial CND8322DS3
UUID {B5F08413-5B62-DD11-986E-001EEC9E1AE6}
SKU FF394PA#ACJ
family 103C_5335KV
DMI Baseboard
model 30D9
revision 83.21
serial CND8322DS3
DMI System Enclosure
chassis type Notebook
chassis serial None
DMI Extension Slot
designation PCI Express Graphic X16
type A5
populated no
DMI Extension Slot
designation PCI Express-0
type A5
populated no
DMI Extension Slot
designation PCI Express-1
type A5
populated no
DMI Extension Slot
designation PCI Express-2
type A5
populated no
DMI Extension Slot
designation PCI-0
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI-1
type PCI
width 32 bits
populated no
DMI OEM Strings
string[0] $HP$
string[1] LOC#ACJ
string[2] ABS 70/71 79 7A 7B 7C
DMI Processor
manufacturer Intel(R) Corporation
model Intel(R) Pentium(R) Dual CPU T2390 @ 1.86GHz
clock speed 1866.0 MHz
FSB speed 533.0 MHz
multiplier 3.5x
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 2048 MBytes
max# of devices 2
DMI Memory Device
designation DIMM0
format SODIMM
type unknown
total width 64 bits
data width 64 bits
size 1024 MBytes
DMI Memory Device
designation DIMM2
format SODIMM
type unknown
Graphics
Number of adapters 2
Graphic APIs
API Intel I/O
Display Adapters
Display adapter 0
Display name \\.\DISPLAY1
Name Mobile Intel(R) 965 Express Chipset Family
Board Manufacturer 0x103C (0x30D9)
Memory size 256 MB
PCI device bus 0 (0x0), device 2 (0x2), function 0 (0x0)
Vendor ID 0x8086 (0x103C)
Model ID 0x2A02 (0x30D9)
Performance Level 0
Display adapter 1
Display name \\.\DISPLAY2
Memory size 256 MB
PCI device bus 0 (0x0), device 2 (0x2), function 1 (0x1)
Model ID 0x2A03 (0x30D9)
Performance Level 0
Win32_VideoController AdapterRAM = 0x10000000 (268435456)
Win32_VideoController DriverVersion = 6.14.10.4885
Win32_VideoController DriverDate = 10/29/2007
Monitor 0
Model LP154WX4-TLCB ()
ID LPL3101
Serial
Manufacturing Date Week 0, Year 2008
Size 15.4 inches
Max Resolution 1280 x 800 @ 59 Hz
Horizontal Freq. Range 0-0 kHz
Vertical Freq. Range 0-0 Hz
Max Pixel Clock 0 MHz
Gamma Factor 2.2
Monitor 1
ID LPL3101
Serial
Size 15.4 inches
Gamma Factor 2.2
Monitor 2
ID LPL3101
Serial
Size 15.4 inches
Gamma Factor 2.2
Software
Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
DirectX Version 10.0
Please Decide by this information will that ram above will work on this laptop or not...
Thanks for patience
