Question Comparision help for some RX 6800 XT and RX 7700 XT products
cihs
9
Comparision help for:
XFX Speedster SWFT 319 AMD Radeon RX 6800 XT - 535 USD
Radeon Turf RX 6800 XT Gaming OC 16 GB - 555 USD
Gigabyte Radeon RX 770 XT Gaming OC 12 GB - 510 USD
ASUS Dual RX770XT OC Edition - 510 USD
Maybe I can squeze in a
Radeon VGA NITRO+ RX 6900XT SE GAM OC 16GB - 583 USD
If you think that would be a very good long term investment.
I will buy once and use for at least 4-5 years.
I have a 5700X3D CPU. I have 8 GB x3 Ram (I believe it is 2100 MHZ)
I couldn't find any good comparisons.
Thanks
PS: In my country because of taxes everything is 30 percent more expensive. That limits me a lot. Also many products' prices do not drop in time.
PS: I know SWFT 319 RX 6800 XT is very long. It looks like I can fit it inside so no worries there.
RX 6800 XT is on sale and only 40 USD more than RX 7700 XT.
I can also afford ASUS Dual RX770XT OC edition.
Thanks
The different brands will not make much difference in the results.
View: https://www.youtube.com/watch?v=RUQ35MXyZrU
Some are overclocked. Some has 2 fans. According to an article Asus Tuf has a bit more clock speed etc. Don't they matter at all? Is it just marketing?
It matters a bit. If you compare different models of the same gpu ( assus tuf 4070 vs asus rog 4070 vs msi 4070...) there are a few precent differences in terms of performance, but its very little and it depends on a lot of things.
Since the prefomrance difference is so small i usually just look for the best cooling and price combo from a reputable brand. There are cards that are made with overclocking in mind with custom pcbs but they are a lot more expensive usually and it doesn't make sense to buy them for the still relatively small performance difference
Three fans are generally better than two but two large fans on a large heatsink can do just as good. Best advice is just look for reviews for the specific model you are looking at, youl usually find someone with an unboxing and some tests
Where I stand to be corrected, it is my semi-uninformed opinion based on older information that the 6800XT is a better card than the 7700XT and in some circles considered better than the 7800XT. I purchased a 7800XT anyway and since it has met my needs in a very satisfying way, I have not gone to seek out further confirmation on that based on the maturity of drivers and whatnot.
