Compatibility and Requirements For Computer Parts Questions
ultrautoob
33
So I am about to buy a new computer (the parts to build one) and I need to know some things about the parts first before I buy. If you could help me out that would be great.
1. Are these parts compatible? Will these parts all work with each other and not somehow make the computer not function?
2. Is the power supply powerful enough to handle this PC, or do I need to get a better power supply (more watts/different brand/ETC.)
3. I still have to buy windows, and I know I can buy it safely from (lets say) BestBuy for around $100, but I've also heard there are other ways to get the operating system. I have heard of downloads for free, very cheap prices off Ebay (my case won't take discs), messages popping up about copys of windows "not being genuine". Should I buy the operating system for $100? I'd rather go the cheaper way, but I need someone's opinion.
4. Is this a good setup for gaming on high end games (such as ARK and Rust)? Is there anything you would change to make this build better? Anything that could give me the same quality of gaming for a better price?
5. Anything else I should know?
Specs:
Monitor: MSI Optix G27C2 27" Curved FHD 1080p 1ms (MPRT) 144Hz 110% sRGB Widescreen LED Backlight LCD/LED AMD FreeSync Gaming Monitor 300 cd/m2 HDMI DisplayPort DVI, Tilt ($278.61 @ Newegg)
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor ($359.89 @ OutletPC)
CPU Cooler: CRYORIG - H5 Universal 65.0 CFM CPU Cooler ($46.89 @ OutletPC)
Motherboard: ASRock - Z370 Extreme4 ATX LGA1151 Motherboard ($149.99 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory ($144.99 @ Newegg)
Storage: Storage: SAMSUNG 970 EVO M.2 2280 500GB PCIe Gen3. X4, NVMe 1.3 64L V-NAND 3-bit MLC Internal Solid State Drive (SSD) MZ-V7E500BW (147.99 @ Newegg)
Storage: Hitachi - Ultrastar 7K3000 2TB 3.5" 7200RPM Internal Hard Drive ($49.99 @ Newegg Marketplace)
Video Card: MSI - GeForce GTX 1080 Ti 11GB ARMOR Video Card ($629.99 @ Newegg)
Case: Fractal Design - Focus G (White) ATX Mid Tower Case ($49.99 @ Amazon) (ALREADY BOUGHT THIS CASE)
Power Supply: Antec - Earthwatts Gold Pro 650W 80+ Gold Certified Semi-Modular ATX Power Supply ($73.69 @ Newegg Marketplace)
The total is $1,899.02.
Thanks!
if you can wait a few weeks to order the video card look at the newer rtx 1070. for the same price as the older 1080ti it may be a better gpu. on your power supply also look at the seasonic focus units. if your going to use two gpu latter on go with an 850/1000w power supply. for windows 10 you can use an 8g usb stick and use the free microsoft media creation tool to make a bootable 1803 iso usb stick. when you install windows click on skip i dont have a windows key. windows 10 will have a small message it not registered and will run fine till you can buy a key from newegg or a known good seller. with the 1803 installer if you have a valid windows 7 key you can still get the free upgrade to windows 10. another thing to email microsoft support is with some version of windows 10/7 you can now move the os key from one pc to another. the last free way to get a windows 10 key is to be a windows insider tester. if you dont mind testing next version of windows on weekly updates. it not to bad. i been a tester for a bit now. not for people that dont like to nuke and pave there main os drive if the update bricks there pc.
