Compatibility check / problems, 2nd Opinion And suggestions / Upgrade
Shinxe
Build
CPU : i5 4690k
GPU : XFX R9 280x double dissipation [already owned]
Motherboard : ASRock Fatal1ty Z97 Killer ATX LGA1150 Motherboard
HDD : Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive [already owned] Has Windows 8.1 already installed from my current build.
Ram : Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory [ already owned]
Case : NZXT s340 white
PSU : EVGA 600B 600W 80+ Bronze Certified ATX Power Supply [already owned]
Water-cooler : Swiftech h220-x
Just Checked For compatibility issues on PCPartpicker,And Seems Everything Is Fine.Since You Already Own a Graphics Card And Stuff,You're Good To Go.And.......Great CPU Cooler Choice Mate 😉
yeah i plan on overclocking the cpu quite a bit
