Compatibility Concern between ASUS Maximus X Hero and M.S and SATA Hard Drives
Jul 9, 2018
4
I am building a machine learning computer to help with my PhD studies involving natural language processing and machine learning classification tasks, and came across the following potential error message while using PCPartPicker.com: PCPartPicker part list / Price breakdown by merchant
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor ($347.89 @ Amazon)
CPU Cooler: Corsair - H115i PRO 55.4 CFM Liquid CPU Cooler ($129.99 @ Amazon)
Thermal Compound: Coollaboratory - Liquid Ultra 0.15g Thermal Paste ($12.89 @ OutletPC)
Motherboard: Asus - ROG MAXIMUS X HERO (WI-FI AC) ATX LGA1151 Motherboard ($248.79 @ Amazon)
Memory: G.Skill - Trident Z 64GB (4 x 16GB) DDR4-3200 Memory ($830.98 @ Newegg)
Storage: Samsung - 970 Pro 512GB M.2-2280 Solid State Drive ($228.99 @ Newegg Business)
Storage: Toshiba - X300 5TB 3.5" 7200RPM Internal Hard Drive ($138.88 @ Other World Computing)
Video Card: EVGA - GeForce GTX 1080 Ti 11GB SC2 HYBRID GAMING Video Card (2-Way SLI) ($799.89 @ Amazon)
Case: Phanteks - Enthoo Evolv ATX Glass ATX Mid Tower Case ($129.99 @ Newegg)
Power Supply: EVGA - SuperNOVA P2 1200W 80+ Platinum Certified Fully-Modular ATX Power Supply ($205.88 @ OutletPC)
Total: $3874.06
Generated by PCPartPicker 2018-07-10 12:20 EDT-0400
In the Compatibility Notes section on the bottom of my PCPartPicker page, it lists the following potential error: "The motherboard M.2 slot #1 shares bandwidth with a SATA 6.0 Gb/s port. When the M.2 slot is populated, one SATA 6.0 Gb/s port is disabled."
Is this something that I need to be concerned about, given my selection of the Samsung SSD and Toshiba HD, or will my motherboard be able to work with both parts fine because it has other M.2 and SATA slots (https://www.asus.com/us/Motherboards/ROG-MAXIMUS-X-HERO/#spec)?
Thanks in advance!
You have no reason to be concerned given the drive configuration you are intending to use. Usually the last SATA port is the one disabled. Just use the first one for the HDD. GTX 1180 is expected to come out next month, just as an FYI. Also if your intended software is highly multithreaded, a 2700x base rig would be a better choice. I cannot think of any reason 64gb ram would be necessary either. Even if you do, you can get less expensive ram than that kit.
CPU: AMD - Ryzen 7 2700X 3.7GHz 8-Core Processor ($309.90 @ SuperBiiz)
Motherboard: ASRock -...
Motherboard: ASRock - X470 Master SLI/AC ATX AM4 Motherboard ($139.99 @ Newegg)
Memory: G.Skill - Sniper X 64GB (4 x 16GB) DDR4-3600 Memory ($700.98 @ Newegg)
Case: Phanteks - Enthoo Evolv ATX Glass ATX Mid Tower Case ($149.99 @ Newegg)
Power Supply: EVGA - SuperNOVA G2 1300W 80+ Gold Certified Fully-Modular ATX Power Supply ($179.99 @ B&H)
Total: $3578.49
Generated by PCPartPicker 2018-07-10 17:01 EDT-0400
