Compatibility CORSAIR HYDRO SERIES H55 AIO And H60 Liquid CPU Cooler with i5 8400 socket LGA-1151?
sumit3322
92
i want to know can i install CORSAIR HYDRO SERIES H55 AIO Liquid CPU Cooler, or Corsair Hydro Series H60 AIO Liquid CPU Cooler
with i5 8400 LGA 1151 socket ?
Yes it will mount to LGA 1151 and work with that CPU so long as your case has a 120mm fan port to mount the radiator to. Be aware that lower end AIOs don't offer cooling performance significantly better than midrange aftermarket air coolers and you can't overclock the 8400, so unless you are looking at an AIO purely for aesthetic reasons, it's not really worth getting one.
Thanks a lot SIR for honest reply
i will surly get Cooler Master Hyper RR-212E-20PK-R2 LED CPU Cooler.
Is this air cooler give me adequate performance .
or if any other one is in your view please let me know.
It's an okay midrange air cooler, it will work so long as your case has clearance for a 160mm tall CPU cooler. Realistically, you probably don't need an aftermarket cooler for the 8400, it doesn't run as hot as the 8700 and unless you plan on running this PC in a hot room with typical ambient temperatures of 35 to 40 celsius, you would probably be okay with the stock cooler.
yes in our location the temp are ambient temp are pretty high summer its around 40-45 celsius
and planning to buy the mid tower atx cabinet Corsair Carbide Series CC-9011050-WW Mid-Tower Steel Gaming Case with Red LED (Black)
so it can fit in that cabinet.?
