Question Compatibility Help
Junior2725
I'm thinking about upgrading my pc and trying to figure out if I can get away with only replacing the motherboard and processor at the moment. I would like to hold off on upgrading ram etc. Let me know if you see any compatibility issues.
New CPU: Intel - Core i7-10700K
New Motherboard: ASUS - ROG STRIX Z490-E GAMING
Existing Ram: CORSAIR Vengeance LPX 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4
Existing CPU Cooler: Hsd a Corsair Water Cooler but it died (what started this process) Hoping to use Cooler Master Hyper 212 Plus until I get a new water cooler at a later date
Existing SSD: SAMSUNG 950 PRO M.2 2280 512GB PCI-Express 3.0 x4 Internal Solid State Drive (SSD) MZ-V5P512BW
Darkbreeze
Retired Mod
The 212 series coolers are not sufficient for the 10700k, which can hit over 200w under full boost conditions. So no, that cooler is not a good or suitable choice. In truth, the very MINIMUM CPU cooler you would want to use would be some form of decent model 140mm slim heatsink fan assembly, and you would REALLY be much wiser to go with a thick or twin finstack 140mm heatsink model, or a 280mm or larger AIO, or a custom loop.
Obviously, most people aren't going to do a custom loop, so a 280-420mm AIO is a fine choice if you don't mind replacing your cooler every 4 or 5 years, as that is generally about how long they last so long as they don't have a premature pump failure. Air cooling is a lot more reliable long term, and is generally quieter too. It also avoids potential damage from leakage issues that even the best AIO and custom loop coolers might develop.
As far as your memory is concerned, what is the exact model of your memory kit, or at least, what is the advertised speed and latency of your kit? Also, what case do you have because a lot of things, like motherboard and CPU cooler compatibility are going to be dependent on the case model.
Junior2725
Thanks for you help. I was worried that CPU Cooler wouldn't work. I had a Corsair Hydro Series H110i GT that I think leaked killing my computer. I'm not sure yet if it is salvageable or not with an old motherboard I had a on hand.
My memory is CORSAIR Vengeance LPX 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Intel XMP 2.0 Desktop Memory Model CMK16GX4M2B3200C16 . Speed is DDR4 3200 (PC4 25600) . Latency is 16.
My case is a Corsair Obsidian Series 750D
Thanks for you input.
Darkbreeze
Retired Mod
That memory should work fine with the newer system. Intel platforms have very good compatibility with a wide range of kits and specifications, unlike Ryzen that is sometimes very finicky about it. That doesn't mean all memory kits will work with all Intel platforms, but it's certainly much more LIKELY to and also unlike Ryzen, most Intel consumer platforms work well with Corsair LPX kits.
With the 750D I imagine you are good to go with just about any cooler you want to use.
Other than a cooler, I think you're fine with just what you have and sticking to replacing the motherboard and CPU should work fine. As far as the cooler is concerned, these would be my primary recommendations.
Below is my list of preferred CPU AIR coolers, also known as Heatsink fans (HSF).
Do not look here for recommendations on water/liquid cooling solutions. There are none to be found.
BEFORE seriously considering ANY cooler, make sure to compare it's height with the maximum CPU cooler height supported by your case. If a cooler won't fit, then there isn't much point in looking at it anyhow unless you are willing to replace the case with a larger, more accomodating model. It should probably go without saying that the recommendations below are NOT intended for systems that incorporate small form factor or mini ITX type enclosures. These are generally for standard ATX tower cases. For recommendations on coolers for very small enclosures, there are many of us around here that can offer some suggestions based on the use case.
A good air cooler works just as well for most applications. There are very few instances I can think of where an AIO will work better than a good air cooler, and even fewer where an AIO will outperform an air cooler if you are willing to buy the right air cooler and then level up by adding some even higher end fans to it.
Loops leak. Heatsinks don't. Pumps fail, FAR more often and usually with far worse consequences, than fans do.
And unlike a heatsink fan assembly, when your pump fails for 99% of AIO coolers, you will be replacing the whole thing, for another 100+ dollars, rather than just a 25 dollar investment for the failure of a fan. Especially since I've rarely seen dual fan coolers have both fans fail at the same time, but even if you factor in two fan failures that's still only about fifty bucks compared to the 100+ it will cost to replace an AIO with a failed pump. And you WILL have a failed pump on most AIO coolers within three years of purchase. Seeing one last longer than five years is possible, but it is not particularly common and we often, very often, see them fail at around the 3 year mark. Sometimes much sooner.
Pump quality and longevity is an area that needs GREAT improvement before AIO coolers will become a primary recommendation for me.
I see a lot of AIO coolers leak and damage hardware as well.
Certainly there are situations where an AIO is called for, or even preferred, but those are MOSTLY aesthetic considerations, because let's face it, a build with an AIO or custom loop generally "looks" a lot cleaner than one that has a big heatsink taking up half the real estate inside your case. When that is the case, I have recommendations for those as well, but I don't offer them unless somebody is specifically asking to go that route.[/B]
They are basically listed in order of preference, from top to bottom. To some degree that preference is based on known performance on similarly overclocked configurations, but not entirely. There are likely a couple of units that are placed closer to the top not because they offer purely better performance than another cooler which is below it, but potentially due to a variety of reasons.
One model might be placed higher than another with the same or similar performance, but has quieter or higher quality fans. It may have the same performance but a better warranty. Long term quality may be higher. It may be less expensive in some cases. Maybe it performs slightly worse, but has quieter fans and a better "fan pitch". Some fans with equal decibel levels do not "sound" like they are the same as the specific pitch heard from one fan might be less annoying than another.
In any case, these are not "tiered" and are not a 100% be all, end all ranking. They are simply MY preference when looking at coolers for a build or when making recommendations. Often, which HSF gets chosen depends on what is on this list and fits the budget or is priced right at the time due to a sale or rebate. Hopefully it will help you and you can rest assured that every cooler listed here is a model that to some degree or other is generally a quality unit which is a lot more likely to be worth the money spent on it than on many other models out there that might look to be a similarly worthwhile investment.
Certainly there are a great many other very good coolers out there, but these are models which are usually available to most anybody building a system or looking for a cooler, regardless of what part of the world they might live in. As always, professional reviews are usually an absolutely essential part of the process of finding a cooler so if you are looking at a model not listed here, I would highly recommend looking at at least two or three professional reviews first.
If you cannot find two reviews of any given cooler, it is likely either too new to have been reviewed yet or it sucked, and nobody wanted to buy one in order to review it plus the manufacturer refused to send samples out to the sites that perform reviews because they knew it would likely get bad publicity.
IMO, nobody out there is making better fans, overall, than Noctua, followed pretty closely by Thermalright. So if you intend to match case fans to the same brand on your HSF, those are pretty hard to beat. Of course, Corsair has it's Maglev fans, and those are pretty damn good too, but they tend to be more expensive than what are in my opinion better fans by these other two, so while they are good products they don't have the same noise characteristics and are probably better suited for configurations where sheer brute force is preferred over low noise that still gives good performance. Also, as with most fan models out there, don't look at the specifications for the non-RGB Maglev fan models and think that you'll be getting the same specs on any RGB versions, because you won't. Fans with RGB tend to sacrifice both maximum CFM and static pressure for the right to stuff the RGB electronics under the hood.
From top (Best option) to bottom (least option)
Noctua NH-D14 (Replace stock fans with NF-A14 industrialPPC 2000rpm)
Noctua NH-D15/D15 SE-AM4
Noctua NH-D14 (With original fans)
Thermalright Silver arrow IB-E Extreme
Cryorig R1 Ultimate or Universal
Be Quiet Dark rock Pro 4
Thermalright Legrand Macho RT
Phanteks PH-TC14PE (BK,BL, OR or RD)
Deepcool Assassin III
Thermalright Macho X2
Thermalright Macho rev. C
Thermalright Macho rev.B
Thermalright ARO-M14G (Ryzen only)
SilentiumPC Fortis 3 HE1425
Thermalright Macho direct
Noctua NH-U14S
Thermalright true spirit 140 Direct
FSP Windale 6
Scythe Ninja 5
Scythe Mugen max
Scythe Mugen 5 rev.B
BeQuiet dark rock (3 or 4)
Thermalright Macho SBM
Cryorig H5
It may not be obvious, but is probably worth mentioning, that not all cooler models will fit all CPU sockets as aftermarket coolers generally require an adapter intended for use with that socket. Some coolers that fit an AMD platform might not fit a later AMD platform, or an Intel platform. Often these coolers come with adapters for multiple types of platforms but be sure to verify that a specific cooler WILL work with your platform before purchasing one and finding out later that it will not.
